QUOTE(aylanco @ May 10 2007, 11:24 AM)
Any suggestions as to how and where to route it?
they *should* already be there. remove the console and look for a connector with a green/black wire.
that's for the oil-temp.
it comes out of the main harness in the engine bay on the pass. side, under the battery tray. again a green/black wire with a plastic connector.
simply run a wire from the taco plate to that connector, plug that gauge into the connector under the console and you're good to go ...
btw. the haynes manual has a wiring diagram, just in case you get lost ...
Andy
