Full Version: Correct fuel pressure for dual carbs?
terrymason
I'm having alittle trouble getting my dual carbs dialed in, the 1st is rich, and the second is lean. My fuel pump was putting out 3.5psi, but the guy I bought my carbs from said I should run 2.6psi instead. What do you guys think?
I've got 60 idle jets and 180 mains, which I thought was overkill, until he told me that I should run 2.6 instead of 3.5 psi.
john rogers
I ran 3.5 PSI with my four cylinder engines and about 4 PSI with the six cylinder. Before you do anything, get a flow meter to see if flow in each barrel is the same. Adjust the carbs so that they are all 4 the same flow. If one side is rich and the other is lean with the same jetting then it could be float levels as raising the float can make the mixture rich and visa-versa. Raising the fuel pressure is the same, makes it richer, etc.
So.Cal.914
3.0 lbs.
lotus_65
2.5 lbs
SGB
60s are mighty big. How big is the motor?
for mains, 125s are about right for my 2.o, but I run 50 idle jets, and 180 air jets.
type11969
The self-regulated pumps sold by VW shops for dual carb applications are set to 3.5psi.
Have you checked and set the float heights? That can make a big difference.
rhodyguy
any other symptoms? snapping/popping back thru the carbs as you open the throttle plates? back fire on decel? my first thought is you've got the droplinks misadjusted if the timing and valve adjments are correct. one droplink longer than the other creating a condition where one carb is 'ahead' of the other. the one "ahead' might be set correctly and the other carb is running lean. don't use the idle speed adj screws to try and correct this condition. it won't work. tearing your carbs apart is the last step when all else fails. get out the cb weber tech book and what ever syncro tool you have, go to the pre dial in settings (the cb book is pretty clear on how this is done), with 1 (leave the other alone for now) idle speed adj screw turn the idle up to about 2k and measure the flow on the front venturis on both carbs. if the flow indicated is equal, go to the troubleshooting guide in the book. the conditions and cures are very well discribed.
k
terrymason
I'm running 60 idle jets, 140 main jets, and 175 air correctors. This is a stock 1.8L with dual dell 40s that I've been fighting for a while.
All 4 barrels are flowing the same amount (around 7 on my unigauge meter).
type11969 - I just went through my dellorto book again, and didn't see any mention of setting the floats, and I have no idea how to go about that. Is it a simple process?
terrymason
QUOTE(rhodyguy @ May 17 2007, 07:35 AM) *
-Yep
back fire on decel?
- No, but my wbo2 gauge reads very lean on decel. My sensor is near the exhaust tip though, so it could be fresh air being sucked in.
I'm using the Dellorto superperformance book, although it sounds like the ideas are all the same.
The passenger (1) side carb seems fine, maybe alittle rich, and the driver side (2) seems lean, and backfires out the carbs. It sounds like you may be on to something here. I'll go back to my book.
rhodyguy
sometimes a bit more info is helpful. no mention of the type of pump, type of fuel presure regulator (stand alone or incorperated in the pump itself) and whether you're using a good fp gauge. how does the engine run when you're off the idle circuit? how the carbs behave at certain engine speeds is important. are the plugs for one carb drastically dif colors? are you measuring the flow at idle 850-900rpm?
k
type11969
If you have the dellorto superperformace tech book, it is definitely in there, I don't have the book in front of me though so I can't quote the page. I believe it is after the troubleshooting section for the DRLAs. There is a small diagram indicating the height needed at open/closed positions.
It is easy, potentially time consuming though to get dead on. All you have to do is pull the carb top, measure the float position at the extents of its travel against the bottom of the carb top, and set the position to be 5-6mm from the bottom of the carb top in the float highest position, and 12-13mm in the lowest. You change the highest position by bending the forklike tabs that engage the needle valve, and you change the lowest position by bending the tab that contacts the part of the carb top that retains the float (opposite side of the float from the forklike tabs). I pull off the carb top gasket to get an accurate reading. Be careful that the spring loaded pin in the needle valve is not compressed at all during the stroke of the float. This will close the valve prematurely. Make sure it is the forklike tabs that close the valve.
If one float is set to high and the other set too low, one carb will certainly be richer than the other due to the different fuel levels in the bowl (and may also cause fuel to dribble out of the bowl down the carb throat).
I've been fighting with my dells for the past few weeks too, so I feel your pain. I think I solved my biggest issue by realizing that the needle valve were getting closed before I thought because I was compressing that spring loaded pin. The symptom was a high rpm leanout like I was running out of fuel. The way the floats were set, basically I was.
-Chris
terrymason
QUOTE(rhodyguy @ May 17 2007, 07:52 AM) *
k
I don't know what brand pump, but the regulator and 2 inline fuel gauges are sceptre brand that I got from pep boys. I've stopped using the fuel regulator (cranked it up to 5, it's max), and both pressure gauges (one before each carb) read a steady 3.5 out of the pump.
Having said that, I'm getting a new pump and jets (may not need the jets) from CB performance as soon as the west coast wakes up.
I have only measured fuel pressure at idle, something for me to do when I go home.
Car seems to idle fine, but when I goose the gas, I get a backfire out of the 2nd carb.
I've only pulled the plugs on the 2nd carb (backfiring one), and they look ok. I'll pull all the plugs tonight.
Thanks everyone, it sounds like I've got a good list of things to try when I get home. specifically:
1. measure the flow around 2K rpm - verify that it's 3.5
2. lengthen the linkage on my lean carb to verify that their isn't a situation where one is leading the other.
3. pull and compare all plugs
Once I get my new pump in the mail, I'll throw that it. If that doesn't fix things, I'll open my carb up and adjust the float level.
rhodyguy
the only reason i suggest turning the idle up is to steady the needle on your syncro tool. the pulsing at reg idle can make the neelde flucutate a bit. i prefer a steady reading. if the front 2 throats are flowing the same, move on to the next step. there's lots to the equation...potencial vac leaks at the intake to heads all the way to the base plates for the linkage. you'll like the self regulated rotary pump from cb. start with a set of 50s for the idle jets. cb should have them. also, ask if they have the little o-rings for the idle jet holders. now would be a good time to replace them when you do the jet change. get 8 of them, i think they are the same as the ones for the idle/air mixture needle screws. piece of mind.
k
ps they're open right now
TravisNeff
does your pump rattle a bunch? That would be an indicator of a facet fuel pump (not the best). Looks like a square box with a fuel fitting on either side.
type11969
Check to make sure your idles are clear, also verify that your pump jets are flowing and that the volumes are correct. Either of these can cause backfiring/hesitation.
Spend the time to set your floats anyway, the more you can get your carbs dialed in to each other, the better they will run!
-Chris
terrymason
I talked to Aaron from CB performance, who was awesome. He asked some really good questions, and I think has put me on the right track. A couple of things that came from it.
1. covering the barrel of the first carb will kill the engine - covering the barrel of the second carb does nothing.
2. no amount of adjustments seem to do anything to the second carb.
It really sounds like I have a air leak in my second carb. When I go home tonight, I'm going to spray carb cleaner around and see if I can find it. That would pretty much explain alot of what I'm seeing.
rhodyguy
"no ammount of adjustments"...are you refering to the idle air mixture needle screws? if so, plugged jet or issues with the circuit. you're getting close. closing off both throats (one at a time) on the suspect carb has no effect?
k
type11969
Plugged idle jet or circuit
terrymason
QUOTE(rhodyguy @ May 17 2007, 09:15 AM) *
"no ammount of adjustments"...are you refering to the idle air mixture needle screw? if so, plugged jet or issues with the circuit. you're getting close. closing off both throats (one at a time) on the suspect carb has no effect?
k
The mixture screws seem to have no effect on the 2nd carb (the speed control does). On the first carb, closing just the first throat (at idle) will kill the engine. On the second carb, it has no effect. I haven't tried closing both throats, as I wasn't thinking to test that, I just happened to notice it.
Luckily, I get off work at 4 today. I'm pretty excited check this out!
terrymason
QUOTE(Travis Neff @ May 17 2007, 08:57 AM) *
It is pretty loud. You can hear it at a stop light with the engin on. I'm going to order this:
http://cbperformance.com/catalog.asp?ProductID=577
unless anyone has a better one.
TravisNeff
Sounds like you do have a facet pump. The CB rotary is a way, way better pump.
rhodyguy
facets suck. get #3193. the canister to the right of the pump is a carter fuel filter. you can use it or remove it and use a stock fi filtr if you want to. use andy's jumper wire fuel pump power trick (classics) if you are not doing so now. did you order smaller jets?
k
terrymason
I have some 46 and 52 idle jets at home (60s installed). I told Aaron this, and he seemed to think that I would be better off with a 65 or maybe a 70. I'll hold off on rejetting until I get everything else setup - I'm tired of chasing my tail on those jets for now.
I've ordered the rotory pump, and new gaskets for my carb. I'll keep everyone posted.
type11969
I'm running a 1.8, little warmed over than stock, I'm at 55's right now, maybe could go to 57s so I doubt for you anything over 60 is really necessary.
Have you pulled the carbs completely apart after you got them from Alfa1750? I had some mismatched parts in mine, and the float heights were way out of whack.
Also, do you have jet gauges to verify that the jets you are installing are the same?
Good luck!
-Chris
anderssj
Terry,
I have some spare jets here in Yorktown--maybe even a set of 65s as Aaron mentioned--you're welcome to try them out. Should be around this weekend--PM if you want to come get them.
The 65s may be a little too big though . . . I'm runnning 30mm venturis, 55 idle jets, 135 mains, 180 air correction, and 9164.2 emulsion tubes . . . on a 2.0 with elgin cam and euro P/C set.
Gint
QUOTE(terrymason @ May 17 2007, 10:08 AM) *
You mentioned once that you were going to check/change linkage adjustment for one carb. If you haven't verified that the carbs are sync'd *without* the linkage attached, then you are not starting at ground zero.
No amount of adjusting the the carb that doesn't seem to do any good is worth much until you've verified that the carbs are sync'd *without* the lnkage attached.
Seriously, start over, from the beginning. Remove the linkage and sync the carbs without the linkage attached. Then try adjusting that carb and see what happens. Personally, I'd start at the very begining (in fact I just did two weeks ago) and rebuild the carbs and set those floats first.
type11969
I fought with my dells and got sick of second guessing so I pulled them completely apart. Rule out everything internal, get them spotless, make sure everything is matched, then worry about syncing them, etc.
r_towle
You may have a simple air leak at the intake bolts, or where the carb bolts to the manifolds.
Rich
terrymason
Well, I believe that I've found the main problem. It looks like the intake on the second carb is alittle warped where it mates to the carb. when I lay a level across the top there is a bit of a raise in the middle, so it rocks back and forth when it should be perfectly flat.
I can see from the gasket that cylinder 1 has been getting air, and the gasket is soaked with fuel.
Gint - you make a great suggestion. Since I'm going to have to take everything apart to change out the intakes I'll go ahead and start from scratch.
Gint
It just plain makes good sense. You'll establish a baseline, know your floats and such are set properly, know what all of your jet sizes are (for certain), etc... Then if you have problems, you're not chasing stuff that you *know* isn't a problem or second guessing yourself.
Aside from a tiny stumble at steady throttle (which is probably a vacuum leak from sloppy throttle shafts or as you have discovered warped manifolds or carb bases) mine is now running better than it ever has since I've owned it. Even with a 009 installed.
terrymason
I'm still fighting this thing, and am ready to pull my hair out.
I've replace what I thought was the problem (new intakes) - but that made no difference.
So, I've removed the top of my carb, and am attempting to set the float level. My Dell book tells how in a general way, but does not list a specific distance they should be from the top. Here is a video if you don't mind looking:
Video of my Dellorto floats
Also, when covering up the 2nd carb, I can still hear a sucking sound, like there is a leak, even though I've replace the intakes, and made certain to really crank the bolts down.
plug 1 looks fine, plug 2 is black and sooty.
Pulling either plug 1 or 2, while the engine is running doesn't make a huge difference (to the idle sound - I didn't try reving the engine).
I've purchased, but not installed the new fuel pump yet. I wanted to set the float level, and replace the intake first.
