Hey all,
So I discovered that there's a hole for an intermittent wiper relay. Where do I get one? Is it just plug it in and it works?
Also - my wipers don't return when I cut them off. Any ideas why or how to track down where the problem is??
The other problem I have is that the turn signal indicator lights in the RPM guage behave very strangely. Basically - they work fine when the turn signal is on, but they both come on and off together when certain events happen. For example.
Turn car on, indicators are off.
Put headlights on, indicators come on.
Go to main beam , indicators go off.
Turn on fog lights, indicators stay off.
Turn off fog lights, indicators go on again.
Also - you can hear the flasher relay clicking on and off whenever these lights come on or off.
It's very strange. I have checked grounds all over the place (all the bumb holders, behind the dash, etc etc) with a multimeter, and they all seem to be fine.
Everything on the outside of the car works perfectly.
Does anyone have suggestions about how to track this problem down, or what it might be? Please don't just say it's a bad ground, give me ideas about which grounding points to check.
Thanks much,
Fiid.
