orthobiz
May 25 2007, 05:29 PM
I'm getting my mint 74 1.8 liter soon, and as some of you may know, I looked hard this winter before I found my perfect ride. Along the way I found out about a car in Grand Rapids, Michigan, owned by a fellow who spends the winter in Florida. He's now back in Michigan and is getting ready to sell his car. It's a yellow 74 or 75 (he's not really sure) and it may or may not have some rust ("a little around the turn signals"), etc.
So, now I'm thinking "daily driver" because I've gotten this 914 bug really, really bad this year. What could be bad about having TWO cars???
The problem is he has not started it for two years. Probably has untreated gas in the tank, who knows how much gas. And it was stored in a covered pole barn that is unheated (which means zero degrees in Michigan winter).
Can you just charge the battery and try to start it up? Does the tank need to be drained and the lines changed or flushed or what??? Any idea of how long sitting is "too long?"
Thanks for the advice!
Paul
BarberDave
May 25 2007, 05:39 PM
MY 2 CENTS
Drain the gas, Change the oil, Charge the Battery
Try and start it ,it just may fire up,if not start to check out Why.
Come here and ask any questions, there is a wealth of 914 knowledge around
here . Good Luck Keep us informed
Dave
RoninEclipse2G
May 25 2007, 05:42 PM
to be safe I'd drain the tank, inspect the hard lines and replace the rubber fuel lines and filter. that old and stored in cold winters the battery is probably nothing more than a dead core. check the battery cables for corrosion too. if it had oil, I would change that too and prime the system by cranking the engine without fuel or spark. any other suggestions guys?
jd74914
May 25 2007, 05:52 PM
QUOTE(RoninEclipse2G @ May 25 2007, 07:42 PM)
If it doesn't have oil I'd be scared
Anyways, 2 years isn't that long a time. I would do like everyone says and put some fresh gas in, get a new battery, and try to start it. First you might want to try turning it over by hand and putting a little mystery oil in the cylinders just to be safe.
Porsche Rescue
May 25 2007, 05:53 PM
While two years is a long time, the gas may still be good enough to give it a try. Remove the cap and smell the contents. Smell pretty much like gas? Try it. Smell like something else? Drain it.
RoninEclipse2G
May 25 2007, 06:31 PM
QUOTE(Porsche Rescue @ May 25 2007, 05:53 PM)
good point, maybe make a little fuel coctail and top it off if it doesn't smell funny,
ingredients:
1/2 small bottle StaBil fuel stabilizer
1 bottle/can of GOOD fuel injector cleaner (chevron Techron/BG44k)
1/2 quart Lucas Upper Cylinder Lubricant
1 bottle octane booster
mix in 2-5 gallon gas can and fill can with highest octane pump gas you can find, pour in tank, start
Allan
May 25 2007, 06:51 PM
I would recommend that before you do anything, at least change the oil, drain and refill the tank, replace the battery, pull the plugs and crank it over a few times. This way you can get a vague idea of how the fuel system handles pressure that it hasn't seen in awhile, and the electricals.
Even after you have determined that the fuel lines, rails and electricals are up to snuff I would then replace the fuel filter(s) before actually starting it.
Once you have it running, I would only take it out for a few feet and test the BRAKES (even if you have a solid pedal just sitting in the car because BRAKES are you friend).
If you get that far I would seriously look into the BRAKES again before seriously driving...
IMHO that is...
ptravnic
May 25 2007, 08:20 PM
FWIW - We had a car here in Buffalo, stored in a non heated garage that hadn't been started in 5 or 6 years. Sounds like similar conditions to your car in question:
We didn't fuss w/the gas - it had a quarter of a tank.
We replaced the battery (actually pilfered one from another car, but that's another story).
We cleaned up the distributor & points & took a wire brush to whatever grounds we could see in the engine bay.
She fired up & runs pretty well - even idles down to about 1k rpms. I wish the other cars ran as well as that one!
-pt
orthobiz
May 25 2007, 09:23 PM
Thanks for the suggestions.
Some pretty dumb questions (but I really don't know the answers!)
If one drains the tank, where does one rid oneself of the GAS?? Will oil change places, for instance, take it? I have a big portable gas tank for filling our boat.
Come to think of it, what do you do with old oil? Back in the day (like, when I was caring for and driving these cars), I had a Sears oil drainage unit and Sears used to let you bring your old oil in. Now we have a "fake" Sears, filled with lawnmowers, washers and TV's, God help you if you need to order anything, it's like you have leprosy or something.
Paul
watsonrx13
May 25 2007, 09:48 PM
When I drained the gas from my tank, I put the old gasoline in the in-laws lawn mower....
You can bring your old oil to FLAPS (friendly local auto parts store)...
-- Rob
Eric_Shea
May 25 2007, 10:42 PM
Advice, In "cold storage" in Michigan
Drain the rust. Replace all the floor pans, inner longs, outer longs, front fenders, rear fenders and front and rear trunk pans.
Easy...
(Michigander... I can!)
orthobiz
May 26 2007, 03:53 PM
But what's the best way to get rid of old, old gas? Other than dipping torches in it and storming Frankenstein's castle?
Thanks,
Paul
Porsche Rescue
May 26 2007, 04:06 PM
I suspect the "correct" answer is to take it to the hazardous waste disposal site. I have done less correct things with it in the past, but not particularly proud of it.
Pat Garvey
May 26 2007, 09:59 PM
QUOTE(Eric_Shea @ May 25 2007, 10:42 PM)
Easy...
Eric,
You forgot to mention checking the Frimmen boots on the Kratz bars! Those should also be re-torqued! (the boots, that is)
Pat
Pat Garvey
May 26 2007, 10:04 PM
QUOTE(orthobiz @ May 26 2007, 03:53 PM)
Thanks,
Paul
Hey Paul,
If you storm the castle, be sure to notice the gorgeous knockers on the door (anyone remeber this?).
Seriously, I've got about 4 gallons of 5 year old gas I'd like to get rid of too. Old oil isn't a problem because a local mechanic shops uses it to heat his shop in the winter & will take all I can give him. But gas seems to be different - wants no part of it. Admittedly, I haven't tried very hard to get rid of it & if I had a lawnmower I'd use it there.
Pat
BarberDave
May 27 2007, 05:54 AM
Pat:
I have a ans. to your problem of getting rid of your old gas. Bring it up here, i will let you use in in my mower and cut my grass. ( small yard) . As will my son ( 3 1/2 acres ) . That would make a nice Sun. Trip for you. I wil of course provide mowers and liquid refreshment . Thanks in advance Dave
Bartlett 914
May 27 2007, 08:21 AM
Getting rid of old gas is a pain. Don't run it down a drain including storm drains. If you have a friend with a Diesel you might be able to put some in his tank (small amounts at a time). Also, it will evaporate. It can be placed out in the open in a cantainer with a large opening. If you pour it on the ground, most will evaporate. What goes into the ground will stay in the ground as a contamination. Last but not lease, pute it in your car a little at a time.
jonferns
May 27 2007, 09:00 AM
campfire starter? --JON
orthobiz
May 27 2007, 09:19 AM
Pat: Young Frankenstein
Dave: It's MY gas, not Pat's! And Michigan is far enough away that it'd be hard to haul all that gas down to you...
Paul
VaccaRabite
May 27 2007, 11:32 AM
To get rid of gas, call your local FLAPS and ask where to drop it, or ask the local garage if they will take it (usually yes, but charge a small fee). Or, put it in a gas can, and drop it off at the local fill up joint, put a sign "free gas" and watch the fight erupt as you leave.
When I drained my tank, I just put it right in my Subaru. It was 2 years old, and the car ran fine.
Zach
orthobiz
May 27 2007, 03:40 PM
Thanks,
could "FLAPS" mean
Free_Lance Auto Parts Store????
Paul
BarberDave
May 28 2007, 05:08 AM
PAUL:
FRIENDLY LOCAL PARTS STORE
DAVE
