QUOTE(HalM @ May 26 2007, 05:59 AM)
For those of you with a stock 4 bolt / 15" wheels setup, what size and brand of rubber are you running for DE's and AX? Looking at the TireRack site, there doesn't seem to be many options.
I did a quick search on this without much luck, so I thought I would open it up for discussion.
You're right, the few options are not very good ones.
A 205 section tire is pretty much the smallest size in performance tires.
This is iffy for a 5.5 inch wide rim....marginal for a 6 inch rim and they are happy on a 7 inch wide jobbie. R spec tires (the weapons of choice for AX are 710s & A6s) are considerabily wider that a street tire given the same listed cross section....they cheat.
That said, guys run em' on 5.5s.
