QUOTE(1bad914 @ May 31 2007, 03:51 AM)
I have three wires available, white, gr/bl and bl/wh, the gr/bl and bl/wh show 3.13 volts with ignition on, any idea which one is right?
black/green is for your left side turn signal indicator, black/white is for your right side turn signal indicator.
there is NO white wire to that gauge. in fact, there is NO white wire to any of the gauges.
are you sure it's plain white? if it's white with a blue stripe, it's for your high-beam indicator ...
as always, the haynes manual is your friend. in this case, all the answers were on page 162 ...
Andy
