QUOTE(SGB @ May 31 2007, 04:20 PM)
The only thing back there besides the fan blades is the belt for the alternator. Could you reach in with wire snips and cut anything that seemed like the wire? It will take some good snips, b/c that wire is te-ough. Is it catching or grinding or otherwise causing problems? You might be able to leave it....
Based on how hot the oil was when I got home, I was thinking that the fan was locked up, but there wasn't any belt screeching. I'll give it a try. Thanks, Dane
