QUOTE(Art.Lee @ May 31 2007, 07:23 PM)
My current plans are to strip everything off. go with aftermarket headers and single turbo t3/t4 combo (Not looking to make insane power) . I was shocked at the amount of vacuum lines on this motor! Haven't decided on a brand of EMS yet. Looking for ideas so if you have any suggestions I would love to hear them!
I'd hop on over to www.rx7club.com and check out their Engine management forums. You can read about what some of the other FDs are running,,
but if the budget is gonna get tight(or you just plain wanna learn) I think MegaSquirt would work for you with your original FD stuff. But if that seems too complicated in regards to ignition, you can always use a FC ignition system, which have been proven to work with turbo 13Bs.
What are you doing about your engine mount? SoloRacer has a trick tri-rotor engine mount you might want to use as a starting point. Then again you can always change your front cover and oil pan(and pick up tube) to a GSL-SE type, then the engine mount is SUPER EASY,,,, and I think a fellow club member might have an engine mount made already (too bad I don't remember his name. Twysted1 did a valve job on his crate engine,, his rotary blew) feel free to chime in here with his name oh Twysted1,,,,
In my long winded reply I just realised that unless you are gonna run the entire stock system,, you need a method to meter your oil unless you run pre-mix. I don't know of an aftermarket EMS that will control the electric oil metering pump that your engine has.
-Rob
(I'm long winded because I can finally help!!)
