2.0 djet
Cooler weather here in the Valley (CA) lately...been driving the teener all over!
Yesterday, pulled out of my garage, down around the block and I start to take off at a stop sign and the engine died. I figured I just didn't feather the clutch enough since the motor was cold.
Go to restart...just crank, crank, crank.
I'm getting fuel at 29psi...but no spark out of the coil (zipo). All the connections look good. Disconnected the wires from the Pertronix and checked for voltage at the coil. I checked and I have 12 volts to the positive side of the coil but when I checked the negative side of the coil and the battery (+) I only had 9 volts?? Does this sound like the harness isn't grounding?
Inspected the cap and rotor...look good other than some black dust from rotor to cap wear. The pertronix unit looked good, no smell like it was fried. I never left the key on for more than a momemt when the engine died.
The Bosch blue coil is about 1yr old.
My first guess in the Pertronix went bad, but it's only a couple months old and looks good.
Second guess....something to do with the low voltage on the negative side of the coil.
Looking for some ideas...thanks
