tyler
Jun 11 2007, 09:27 AM
Has anyone installed one of these "Terrys"? A tech article says their expensive (which I don't mind for quality) and there's "too much cable." I don't know what's meant by "too much cable."
Any problems with the installation? It seems straightforward, but there's usually something unexpected.
TravisNeff
Jun 11 2007, 11:04 AM
Very straightforward. The cable itself might be a little thicker than stock, it has been a long time since I have looked at one.
I personally like the stock cables vs. the Terry, better fit at the firewall and less $$.
Trevorg7
Jun 11 2007, 03:13 PM
I replaced mine 18 months ago with a Terry cable. I've had no problems. No issue with length either.
Hardest part was the clevis pin at the peddle assembly.
T
Dr Evil
Jun 11 2007, 05:25 PM
The only tip I can think of is to cut a small piece of tube to put on the threaded cable end at the clutch arm so you dont have to go so far to cinch the nut down.
914-8
Jun 12 2007, 12:59 AM
I've used Terry cables in the past.
I've found them to work, but they are too long (at least they were on my stock 4 cylinder cars).
I modified them to fit, by cutting them down with a Dremel. Not quite as easy as it sounds, because you have to cut the end of the cable housing off, then cut a section of the housing out and reattach the end, but it's do-able. I found that while they worked when too long, the feel was MUCH better when shortened.
Oddly, while the factory cables seem to be a bit shorter than the Terrys, I found I liked the feel of the factory cables when shortened a bit, too. I know the cable needs to have some "slack" to make up for some engine/trans movement, but they seem to have quite a bit of extra length to them, and I've shortened them down with no problem.
Jun 12 2007, 01:04 AM
i just ordered a 914-6 clutch cable from AA and installed it today.
it's thicker than the stock /4 cable and went in without any trouble. perfect fit and should be plenty strong ...
Andy
914Sixer
Jun 12 2007, 08:33 AM
I use stock 914-6 cables on everything. They are only $4 bucks more and more heavy duty.
