QUOTE(Nohair @ Jun 13 2007, 10:48 AM)
Hello- after reading about using the Subaru engine/trans as a unit into the 914 and it sounds like a good way to go- it got me to thinking about using a front wheel drive engine trans- IE: Vw turbo 4 with trans- question I have is will the entire engine/trans be able to mount in the engine compartment with out too much cutting- I have not had a chance to do any measuring but I thought I would ask here- there is a very large amount of knowledge here!!!
thanks very much
nohair(really)
I think the attraction that the Suby powerplant holds is the fact that it's a spiritual successor to the TIV engine with the same boxer engine config. Most FWD inline 4 engines/trans packages don't suit themselves for easy installation into a 914. With that said and out of the way,, If you have a particular affection for a certain front wheel drive engine,, it will take your own creative engineering,, and that's not a bad thing. I wish you good luck with your project,, but you should know your abilities before you take the big plunge.
-Rob
