QUOTE(Chuck @ Jun 17 2007, 12:27 PM)
I went through the same thing about a month ago. The air filter bracket attaches to the motor in 3 spots. I'm sure you already found the bolt on the front of the bracket. What is hard to see are the two little screws on the rear legs attaching it to the motor. I tried everything to get those two loose on my car and just could not do it. So, once I got the front one loose, I simply bent the bracket back enough to give me access to the accelerator cable nuts. It is very straightforward once the bracket is out of the way.
your spot on! I found the single 13mm bracket bolt, but I am having problems finding the other fastners, so I will look for the two other screws. The haynes manual does not show the oil bath filter bracket, only the accelerator cable after the bracket is removed. It's really cramped for space with the FI in the area and being the first time for me with an engine removal, but a good experience. Thanks chuck. Mike P.S. If anyone else out there has run into this situation please chime in.
