[quote name='computers4kids' date='Jun 17 2007, 04:19 PM' post='912472']
[quote name='customstarr' post='912460' date='Jun 17 2007, 04:26 PM']
Are you sure it's not your TS2 (head sensor) going bad? A fautly sesnor could richen all conditions...however it's probably your MPS not holding a vacumm. Try sucking on the tube to the MPS and see if it holds a suction...don't suck to hard you could pop a diaphram. The best way to test is with a vacumm pump at 15lbs.
[/quote]
I'm testing the MPS tomorrow with a vacuum pump/gauge. The CHT sensor looks good (checked per specs with meter).
Just for the record, I've covered the basics: New points, condensor, cap, rotor, plugs, wires, coil, battery cables & terminals, ground straps, battery, vacuum lines, fuel filter, TS1, and more... all Bosch parts. Also checked and adjusted valves, timing, points, etc.
I prey to god that I'm in the final stretch - I'm getting so sick of wrenching on this car versus driving it, I'm just about ready to put it on the sale block. It's a nice car, and the engine is soild, but this rich condition/poor & inconsistant idle crap is testing my will. Damn you D-Jet, damn you!
