A. I saw one pic with a hose connected here. Where does it go?
B. What goes through this hole w/ grommet? Fuel line?
C. I recognize this as where the air duct passes through. I'm not planning to install the heating stuff b/c I'm probably missing half of it. Will that cause problems? I don't have the L & R tin that covers the heat exchangers, either.
D. throttle cable?
E. (no pic) does the clutch cable go through the small hole (on the pass side) of the sideshift engine mount bar?
I can't say "thank you" enough to everyone on this forum who has responded to my questions. It makes the impossible task go much faster. As I learn more, I too will be able to give more back.
