QUOTE(Cap'n Krusty @ Jun 18 2007, 04:32 PM)
Right side of the car, below and slightly forward of the battery. It includes the horizontal surface, the right bulkhead, the firewall, and the vertical surface opposite the bulkhead. If it's not there, it's already too late! The Cap'n
1ST Order of business....
2ND, as the "Cap'n" sez, the repaired area depicted below is where the "hell hole" is found. Oft times it is the cummulative result of spilled battery acid, vented battery vapor, road salt, moisture, leaves, and the general accumulation of road detrius that ends up deposited in that area.
