Chris Foley has a mod for the rear shock tower, to add what looks like a piece of tubing to extend the top mount of the shock up off the inner fender a couple inches, thus giving back some travel to lowered cars. I need to call him and see if a koni shock, with its taller top for the adjustment, and a 914 roof, will all fit with his mod. I need to keep my car dual purpose and be able to store the lid in back when its not on top.
Here's what I'm thinking. If you took out the lower shock bolt, and found some really thick walled tubing with the same I.D. as the O.D. of the bolt, could you weld this tubing on the bottom of the rear trailing arm, in line with the factory hole to maintain as much as possible the same geometry, and in this way gain a couple inches of travel for your lowered car.
waddya all think?
Use of the car is street driving and auto cross, no big track stuff.
