Are the 911 and 914 bearings identical?
Yes. Up to 1974. Then the 911 got a slightly deeper (5mm) and fater bearing. The ID remained 42mm.
The 914 bearing is very common and is used in the early 911, various Saabs, Volvos etc.
Andy "having no problems" is currently living on borrowed time with those slicks.
As the wheel sizes changed with the 911, Porsche beefed up that bearing a bit. Any time you move the wheel out with spacers etc., you also put more strain on the bearing.
All that being said; the 914 bearing is fine for almost "any" application. If you're going to be racing, autocrossing or even spirited driving with larger tires and (heaven forbid) slicks,
you'll probably need to change them more often than a regular 914 would. I've "heard", agressive driving with big'ole tires will net you about 3 years. Only hear-say for now...
The front bearings should be treated the same. The 911 strut has a much beefier spindle and bearings but... again, the 914 bearings should be fine for most "any" application.
