ptravnic
Jun 21 2007, 06:41 PM
Shouldn't they only spit gas @ throttle opening? Is there a setting I'm missing?
Dave_Darling
Jun 21 2007, 09:24 PM
Either the accelerator pumps are leaking, or the linkage to them is too tight and the vibrations of the engine at idle are pushing them just a little bit.
--DD
ptravnic
Jun 21 2007, 09:28 PM
Thanks DD. They are OK @ idle (ie, no gas spitting) so I'm pretty confident they are not leaking. The linkage to them may be in question...
Jake Raby
Jun 22 2007, 06:28 AM
Sounds like you have some engine harmonic issues... did you have this engine dynamically balanced?
Dribbling accelerator pumps make for an untunable engine that always runs rich- no matter what and if harmonics are causing it there is no total cure for it..
ptravnic
Jun 22 2007, 06:36 AM
QUOTE(Jake Raby @ Jun 22 2007, 08:28 AM)
No, it's a somewhat unknown engine BUT it ran fairly strong across the RPM range with the old FI on it.
Jake Raby
Jun 22 2007, 08:51 PM
harmonics won't make injectors dribble :-)
Allan
Jun 22 2007, 08:55 PM
Check your floats.
ptravnic
Jun 22 2007, 09:00 PM
QUOTE(Headrage @ Jun 22 2007, 10:55 PM)
Check your floats.
I set them to 10mm, should it be different?
