bd1308
Jun 22 2007, 04:05 AM
I know its possible, I just know it.
5 speeds in a bus would be helpful.
Only Q would be if the final drive in a bus tranny would be the same in a 901?
in 5th (and 4th) going same speed, RPM seems to be around same in both the 914 and my buddy's bus.
I'm thinking that the 901 would put up with a tad more abuse.
URY914
Jun 22 2007, 06:44 AM
Go to thesamba.com and look in the forum section. They are as wacked out as us when it comes to buses.
type11969
Jun 22 2007, 06:56 AM
901 vs a Bus tranny? No way the 901 will put up with more abuse. Those Bus trannys are what guys in the dunes are using, I doubt you will see many 901s out there.
markb
Jun 22 2007, 08:47 AM
PM Cap'n Krusty. He can probably tell you more than you want to know about it. He did it with the ThunderBus.
Bleyseng
Jun 22 2007, 08:59 AM
you want 5 speeds?
Get a Euro spec 091 5 speed tranny, its more like a close ratio box as its the same final drive .89.
Did you ever locate those shifter parts?? I can use them as I will be rebuilding my 091 in two weeks.
bd1308
Jun 22 2007, 01:46 PM
Geoff,
Its a metal shifter ball ( instead of plastic) that can be bought online from somewhere?
There's also a short shift kit I can pick up this weekend
I'll let you know
