So I took the teener out again this morning . I clamped the AAR valve to eliminate it as a problem, cause the car was running ok with the new fuel filter (yesterday). It barely idles and I'm thinking , it just has to warm up and it'll run fine if the AAR is still not working, it idles like crap all over town , but runs alright when I'm cruising around . A little sluggish when I get to 4K , but cruises fine. Well I'm driving around thinking I'm ok, and I turn to come back home (about 1.5 miles away) and it gets boggy on me again , and the further I go, the worse it gets . Surging, backfiring like crazy , no power , just barely jerking along at like 5 mph.
Could the fuel filter be plugged up again, cause there's a ton of in my fuel tank?
Someone suggested plug wires, I think I'll replace those when I get some $$$, and check the plugs to, cause who knows what condition they're in now.
And of course there's always the vacuum leaks. I'm going to tear out the old air/smog pump crap and put bolts in where the injectors were. And do the propane leak test deal.
Any other Ideas?
