new update on engine build as of 7/28/07, just waiting to order jake raby cam/push rods and misc. to complete parts for build. i can then have idea of build date:
Click to view attachmentPRE-ENGINE BUILD PREP things done and to do:
- sand blast tin, wash, primer, paint DONE
- remove heads/cylinders and any misc. needed from parts engine, clean bench DONE
- clean and lay out case, pistons, rods, bearings and set up table for extra layout of cleaned bolts/parts PARTIALLY DONE
- install new rod bearings, plastic gauge clearances, install and torque rods on crank to ready for build
- hone cylinders/clean pistons and soap wash/compress air dry/oil, have checked for roundness
- have 911 swivels machined .060 and shim rocker stands
- remove fuel injection, engine mount and misc. needed from original motor for new build motor, layout on spare table
2056 ENGINE SPECIFICATIONS:
http://www.aircooledtechnology.com/cylinderheads.htm71mm stroke x 96mm bore
- Len Huffman prepared .039 2.0 Porsche
http://www.haminc.biz/vw/type4.shtml - relocated and sized spark plug
- valve 42x36 mm
- improved seat material and machining process
- 55 cc ported and polished
- chromoly retainers (may have upgraded titanium)
- stainless steel valves
- 2.0 “GA” case
- line bored (0.50mm) .020
- balanced rotating assembly
- all 4 rods/bearings and nuts each at 29.0 ounce exactly
- lightened flywheel
- 2.0 crank turned (o.25mm) .010 main, (0.25mm) .010 rod, std.
thrust and micro polished
- 5 dowel pins flywheel to crank
- oil galleys drilled/tapped and plugged
- 96mm Keith black hypereutectic flat top pistons
- Jake raby RAT 9550 cam/lifters set
- D-jet fuel injection
- pertronix electronic ignition
- 1.7 stainless steel exhaust/monza muffler
- estimated 110-120 H.P.
