ptravnic
Jun 25 2007, 09:38 PM
The only thing I've found is thick rubber hose...
Dave_Darling
Jun 26 2007, 01:31 AM
Someone posted here a few weeks ago that they were able to find a roll of tubing that looked identical (or almost) to the stock tubing at their local hardware store. I recall that it wasn't something I would have expected--possibly electrical conduit type stuff?
--DD
Mike D.
Jun 26 2007, 02:26 AM
It actually looks alot like the hose I use in my pond. They have it at Lowes & Home Depot, comes in different sizes. But a roll of that would do 10 914s... maybe you can buy it by the foot?
highways
Jun 26 2007, 04:02 AM
Yep, I found the irragation house that looks identical to OEM rain tray hose at OSH (Orchard Supply and Hardware). It's not an exact fit though but I found that you can join to the OEM rain funnels to it by using some black joint tubes that are sold also in the irragation section- and the joint can be hidden so in the end it will look original.
The irragation hose is like a black rubber material over a wire ring tube, 1" diameter and sold in 25' sections for like $20... different from the OEM tubes that are straight plastic- but at least it looks exactly the same. The only difference it that it looks slightly glossy.
ptravnic
Jun 26 2007, 08:20 AM
Great info guys - I'll make a trip to HD and/or Lowe's
jim_hoyland
Jun 26 2007, 10:30 AM
Got mine at OSH, a 20+ ft roll is around $25. Traded the unused part of the roll for parts.....
ptravnic
Jun 27 2007, 12:49 PM
WOO HOO! Got some from Home Depot today: 20' for $20. The funnel doesn't fit in as snuggly as the original (hose clamps will easily do the trick).
I tried to find the link on their website for others to track but no luck so I took a pic of the tag. I also pulled an old hose to show side by side comparison.
Click to view attachment...................................................................................................................................
rmital
Jun 27 2007, 01:02 PM
20' of new rain tray hose...that might be just enough to do all your 914s.
ptravnic
Jun 27 2007, 01:32 PM
QUOTE(rmital @ Jun 27 2007, 03:02 PM)
that was what I was thinking... but then there's the hose in the front trunk, behind the gas tank to replace... Lil jobs like this are about the only ones I can do in this heat, it's been low 90's the past couple days
maf914
Jun 27 2007, 03:04 PM
Thanks for posting the photo and source for the tubing. I also need to replace the rain tray tubes. They were fine until I removed them to degrease and clean them. I had cleaned them with a brush and was rinsing them off with a hose. I figured I'd sort of sling it to get the water out with a little centrifugal force and the sudden flexing caused the tube to break. SOB! Probably a little brittle from years of heat exposure.
ptravnic
Jun 27 2007, 09:07 PM
QUOTE(maf914 @ Jun 27 2007, 05:04 PM)
Exactly the reason I had to replace one of my hoses - then figured they could all use modernized.
Glad you found it useful.
-pt
