QUOTE(jmill @ Jun 25 2009, 08:47 AM)
QUOTE(Rav914 @ Jun 25 2009, 10:18 AM)
Interesting. I'm running a Mallory Unilite from another car that had no issues. So I suspect the ignition is just fine.
What ET would you suggest?
(sorry to hijack)
Your idle jet is oversized. I would think a 50 would be perfect and a 55 would be on the rich side. I suspect you bumped it up because you had lean transition issues. If you float level is correct try an F9 ET. It was designed to enrichen the mixture at lower velocities. Tables and calculations in the tech books are great for getting you in the ballpark as far as jet sizes go. They don't take into account what ET your using. ET's have different quirks and were designed for different applications. Check out all the available ET's and what they do for you. Also look into your accelerator pump. Some lean transition issues are due to undersized pump jets.
As far as the original question in this thread. I would have started with those exact same jets.
I agree, I started out with 55 idle jets and found them to be just a bit too rich. I could not get too much of an adjustment with 55's in, so I switched to 50's.
I installed a 2056 in December and am running Weber 40 idf's as well. My jetting is as follows:
36mm venturies
F11 emulsion tubes
130 main jets (Oxygenated California gas)
180 air (San Diego, sea level)
50 idle
I did have some bugs to work out, such as float level adjustment... and also found an issue after the install ~ my needle's were worn where they seat. I replaced them and the car has run very well since.
Your numbers seem like they should work for you for where you live... what venturies are you running?
