QUOTE(Igor @ Jun 27 2007, 11:36 AM)
When you guys say "the motors don't spin the right way" what do you mean?
If the motor spins the wrong way, you will have 1 forward gear and 5 reverse gears instead of 5 forward gears and 1 reverse gear. You'll be able to go real fast in reverse though...
As far as why no one has tried the Honda, as others have said, each motor transplant carries with it many modifications like motor mounts, electronics, and cooling which require some creativity, engineering, and extra costs above and beyond the engine. Even SBC and Sooby's require significant modifications but these are well known and documented and makes subsequent transplants easier.
If you look for a 914, try to get one with a 2.0L engine. Years 73-76 have the 2.0L engine. If you can find one with modifications like 5-lug suspension and/or SBC, Sooby, or Porsche /6 engines in your price range, then start with this.
Also remember that 914 beauty is only skin deep, rust goes to the bone. Hopefully you can get someone familiar with 914's to look at the car with you.
Spoke
