QUOTE(AvalonFal @ Jun 27 2007, 12:52 AM)
Instead of repairing a broken clutch tube weld, PO relocated the tube to the passenger side of the center tunnel. He tapped a long screw at an angle into the tunnel to the bottom to hold the tube tightly in place. Car runs fine with no obvious clutch problems, but my concern is the different angle from the tube that the clutch cable now makes to the pedal attachment. I'm thinking there's got to be more strain on the cable with this setup and I noticed about 1/3 of the clevis pin was worn down. Anyone else see a problem with this setup??
Just got into my clutch cable tube snake pit, the firewall was torn open and a fairly large chunk was still attached to the tube, so a little welding with Oxy/ acetylene tacked it back into place. the tube was completely loose as I was able to extend it several inches beyond the firewall. Then pulled the shift linkage off and here's what I found.
Shifter has gouged a good groove into the clutch tube. Next job is to properly secure the forward end of the clutch tube on the drivers side.
I had not yet run the car so don't know if shifting would be compromised. There were no bushings in any of the shift linkages, so I'm sure shifting was very vague at best.
