Full Version: Spark Plug for 1972 2.4 "T" motor?
Danny_Ocean
Searching proved futile.
Does anyone know which is the correct sparkplug for a 1972 2.4 "T" motor?
Bosch says W5DP0, but that doesn't sound right...
Also heard about W4CS, but that's listed as a "racing" plug.
Pat Garvey
QUOTE(Danny_Ocean @ Jun 29 2007, 07:25 PM) *
Well, it depends a little. Is the 2.4 a carb'd or CIS motor?
Danny_Ocean
QUOTE(Pat Garvey @ Jun 29 2007, 10:33 PM) *
It has MFI.
Cap'n Krusty
The W5DP0 is right for your engine, BP8ES was the alternate (read "cheap") plug when the engine was new, but BP7ES will probably work well with today's fuel. The W5DP0 is major bux, the NGKs aren't. Be prepared for poor transition performance, and there's NOTHING you can do about it. It was that way when they were new, and wear doesn't help. The fix is to change the throttle bodies, have Gus make the pump into an E, and change the cams. Enjoy! The Cap'n
Danny_Ocean
QUOTE(Cap'n Krusty @ Jun 30 2007, 01:43 AM) *
Thanks. I'm swapping to PMO's soon.
