Okay so anyone who might have read my previous thread on the Portland Historic races & getting my car together for it. Well I finished putting the linkage from the firewall to the tranny. I had a little trouble geting my clutch cable on. Just didn't want to pull enough to attacth to the throwout bearing arm. Well I got a little further under to get a better grip. Then it gave enough where I could get it on there. So I am finished under the car. I take it of the stands so I can reach into the engine bay easier. I get everything connected there & I go to start it. Not sure what is going to happen.
So I turn it over & to my shock it started after a few turns. Runs a little on the rough side but evened out after it warmed up. Throttle response is still a little soft so I need to tighten my cable a bit. Well I go to put it in gear & go for a quick spin up the road . I put my fot on the clutch & feel nothing. IT was allready sitting onthe floor . So what the hell did I do? Feel like I am missing some return spring or something. I looked at the pedal cluster & that spring looks like it assists with pushing the pedal down not bringing it back up. I'm a little stumped. Could my clutch tube have decided to seperate from the center tunnel? Please dazzle me with your brilliance & give me an easy fix
