QUOTE(orange914 @ Jul 2 2007, 02:26 AM)
i'll be putting together a 2056 soon. with jakes 9050 cam can i run d-jet and 9.0:1 on pump gas with no problem?
can i be pointed to a thread on this set up proceedure?
This is a good example of why it is very important to take your time (which will be frustrating). Need the heads cc'd and deck height measured to determine which shims are needed to get the CR you desire.
After this is sorted and the right shiims are in and the heads are torqued down, it'll be time to start learning about rocker arm geometry. 911 swivel feet adjusters, adjustable push rod, cut to fit push rod's...
At first you (as I did) probably thought that once the parts arrive it's time to put it all together - maybe even in a day or a weekend BUT rarely does it happen that way.
Enjoy the process!
