BigDBass
Jul 2 2007, 04:22 PM
Brad is finishing up with quite a bit of work on my car. In the next day or so we'll be making the arrangements for pick up. I can't wait to get back behind the wheel.
Last summer I had ignition problems arise. I'd set the timing and it would run ok for a few miles, then sputter and backfire, then run ok... Turns out some of the ignition parts were new, but not exactly the right parts. The points, condenser, and coil were all wrong.
Here's some of what's been done:
Adjusted valves (so I can continue to not do this myself for awhile!)
New points, condenser, plugs, plug wires. Replaced coil with used correct one.
Replaced fuel lines at pump and tank.
Installed front sway bar mounts. (Now gotta find a stock front sway setup.)
Installed SS heat exchangers and Bursch muffler.
Welded cracked hinge on rear trunk lid.
Hmm, that's all I can think of for now...
I'm psyched!
Grelber
Jul 2 2007, 04:32 PM
Check with Doug in Keller, TX. (dgelinas) He had a stock front swaybar he was trying to sell a ways back.
