QUOTE(orthobiz @ Jul 4 2007, 09:41 PM)
QUOTE(retrofit @ Jul 5 2007, 12:15 AM)
Where do you buy it?
AK
You don't. An authorized dealer comes to your car and applies it.
Paul
Not entirely accurate. You can have it applied, or you can buy the film and apply it yourself.
I applied a pre-cut kit to my wife's car 5 years ago, the film and the front end still look like new. This was a modern car, with lots of curves and cutouts, so a kit was necessary.
You can buy the film either in pre-cut kit form, or in standard sheets.
The hood and headlights and headlight blinds on a 914 would be very easy for a DIY'er to do. No problem. It is so straight, you could probably just buy bulk film and cut it to fit. You just need a very, very clean area to do the application.
The 3M film and kits are available everywhere. I got mine from xpel.com and was very happy with it. At the time, they had the best prices, they probably still do, but check around.
The visibility of the film really depends on the application and the color of the car. On a modern car with a once piece plastic front bumper, you hardly notice it, because the edge of the film runs on edges of the bumper. You'd notice it more on a 914 hood, mostly because of the long line running across the hood.
It also gets less and less noticeable the more the panel gets towards vertical. The 914 hood, which is more close to horizontal, will be more noticeable.
It is not very noticeable on metallic silver. From what I've seen, it is fairly noticeable on white. Visibility on other colors vary quite a bit.
