QUOTE(Pat Garvey @ Jul 26 2007, 07:57 PM)
QUOTE(Cap'n Krusty @ Jul 5 2007, 10:55 AM)
QUOTE(Vacca Rabite @ Jul 5 2007, 08:14 AM)
If it were me, I'd pull out all the old fuel lines (including the ones through the center tunnel - and while you are doing that upgrade from brittle burn-my-car-to-the-ground plastic to stainless steel) and replace them and the fuel filter too. Also, I'd replace the alternator pully belt.
There will be no more gas in the car, but I would drain the 20 year old varnish out of the gas tank.
Check the tank for rust. If yes, you are allready 3/4 of the way there to pull the tank and clean it and seal it. If you are lucky, get new gas in it quick.
Change the oil, crank for pressure, and see if it goes BANG.
Zach
"Brittle burn-my-car-to-the ground plastic"? An irresponsible and indefensible statement, statistically speaking. Known instances of failures in the hard plastic lines, OTHER THAN in the external portions subjected to heat and road debris, are pretty much all related to drills, saws, welders, and other destructive forces. Many new cars still use the technology, certainly a sign of the safety of the material 38 years down the road. More common is the failure of the rubber lines, often because Bubba used 3/8" or 5/16" common low pressure line, possibly together with the wrong clamps. Other causes of failure are mostly because the owner or maintainer decided not to inspect and service the hoses in a prudent manner, or the injector bodies have sprung leaks. The Cap'n
Well said Cap'n! In my 35 years ownership of my 914 I've never had a fault with the plastic lines. Never cracked. Never gotten brittle. Never leaked.
Oh yeah - the high pressure rubber dudes have been changed 4 times now, but the plastic endures. I'm with you - it ain't broke & it's factory!
Pat
Cap'n, in the time I've been lurking on this forum, I've observed you argue against changing the plastic lines on several occasions. In the past, I didn't respond, but I will now: I think you're dead wrong about this. Making the claim that the lines are OK because they only turn brittle at the ends is like saying that NASA has never lost a shuttle, except for Challenger and Columbia. It's intellectually dishonest to arbitrarily exempt the failures so that you can then claim a perfect record.
I have only owned one 914. It's probably a safe bet that the majority of people on this forum have owned less than 10. So when you disparage Zach's comment as "indefensible, statistically speaking," you've missed the fact that 10 cars is at least an order of magnitude below what would be a statistically-significant sample. I don't need a statistically-valid sample of 914 fuel fires before I make up my mind about the hazards of these brittle lines -- all I need is common sense. The facts are these -- the plastic lines are 35 years old and they crack. 914s burn. Cracked plastic lines probably contribute to the fires. Replacement lines are cheap and easy to install. In the light of all this, your insistence on keeping the plastic lines seems to me to be the more indefensible position.
I changed my brake fluid last weekend. I did it because the fluid had gotten dark. Would you have me wait until my brakes fail before I do so? Would you also have me wait until my 914 burns before I change the fuel lines? Maybe I should get 100 914s and do a proper statistical burn analysis? Maybe 1000?
And Pat, thank you for the anecdote about your factory-perfect lines. We all respect the effort you put into keeping your 914 factory-pristine and I'm sure most of us envy the condition of your car. But your car rarely gets started, rarely sees an engine heat-cycle, rarely sees inclement weather, rarely gets parked in the sun, rarely gets driven down muddy or wet roads, rarely, in short, gets exposed to the conditions that cause the plastic lines to become brittle. And even if your lines needed replacement, your commitment to absolute adherence to the factory design, good or bad, has compromised your objectivity on the safety of these lines. I don't care about losing concours points. I DO care about losing my car to a fuel fire. You should keep your plastic lines -- they seem to work well for you and the judges. But you should also acknowledge that your 914 is not a representative example and that its perfect condition is not a valid argument for keeping the plastic lines in every other 914.
Here's the final word for the new 914 owner: Change your fuel lines -- if your 914 subsequently burns, it'll be for some other reason than cracked plastic.
