QUOTE(porsche914gt @ Jul 12 2007, 01:09 AM)
The problem with the JWest panel that I installed was this.
On the 73/74 panels, fuse ! & 2 and 3 & 4 are fused together.
They are high beam (white) and low beam (yellow). This is on the input side from the headlight switch.
You need to jumper them together.
The documentation I received said nothing about this.
You can see this on the wiring diagrams or check you old panel, and you will see it.
Not true, fuse 1-2 and 3-4 and 10-11-12 ARE jumpered together internally in the JWest fuse box.
If there is no continuity between the input side of these fuses then there is an issue with the fuse box and you can send it back to me for a replacement.
