check your PMs ...
-------- snipp --------
that's how i have done it in the past. bolt down cylinders using the studs and a flat piece.
do that *without* any shims.
measure the lip height (in mm) from the piston top to the cylinder edge.
that will give you the volume that you need to add to the cc of the head.
use the following to get the volume:
Volume = Pi • r² • height
Volume = 3.14159265 • (96/2)² • lip height
Volume = 7238.23 • lip height
so, for example, if the lip height is 4mm, the top volume that needs to be added to the head cc would be:
Volume = 7238.23 • 4 = 28952.92 = 28.95 cc
(note that you have to divide the inital result by 1000 to convert from cubic milimeters to cubic centimeters)
that means, if the lip height is 4mm, you'll have to add 28.95 cc to each of the head cc.
then use the cylinder cc volume (71mm stroke, 96mm diameter) to determine the compression ratio.
using the same formula to get the cylinder volume:
Cylinder Volume = 7238.23 • 71 = 513914.33 = 513.91 cc
compression ratio = cylinder volume / (headvolume + top volume)
that's your compression ratio without shims. you then add shims to increase the top volume until you get the desired compression ratio.
easy, eh?
Andy
