Well, it's over, and all the advice did help. Thanks a bunch. Unfortunately I couldn't do the official runs. I was just too damn tired, and they were supposed to run 'til 2 a.m. So I decided to cut out early, and driving home, I realized what a good decision that was.
Talking to myself is something that I've always done,
but I made it work for me when I started riding BMX full time. It's a good technique. I only walked the course once, but I did it alone. I didn't even have to ask my brother to let me do it alone, either. He knew that I had to concentrate. The lines I set up when I walked the course didn't end up changing all that much through the night, except the parts where I was like, "I have no idea how to take this, so I'll drive it and see what happens." Unfortunately, my lap times didn't change much either.
I didn't ask for an instructor because I've only got a driver's seat in my car right now.
So I was prettymuch on my own. That was fine, though, because I have trouble watching and learning. I kinda just gotta do it. So first couple runs I got a feel for the course. I Found out which lines that I had set up worked, and which ones didn't. The next few runs, I tried tweaking my lines in my slow areas to see what else I could get out of them, but I was kinda sloppy in the stuff that I thought I 'knew'. The nerves were bothering me a bit, and I was also working harder physically than I had expected. By the end of the session, however, I thought I had a pretty solid run set up. On the final run of the session, I tried to rip through it, and I blew the horseshoe. My tail came around, and I saved it while keeping it between the cones, but it killed my time. I was running between 75.5 and 78 seconds that session.... rather inconsistent.
In second practice I knew what to expect. I made sure to keep myself breathing, and realized that I would be working hard. The nerves were gone and I knew my line would be fast if I could put it together. Once my mind was in the right spot, I took a solid run 1 and put in a low 75. I started looking for fine adjustments to my line and was dropping 1 to 2 tenths a lap in the second session. My times were very consistent. The second to last lap was my fastest of the night at 74.377, but last lap blew the horseshoe again.... worse this time. I got the thing TOTALLY sideways and in full right lock before bringing it back, so that was the end of that. I think part of that is the tire pressures that I was running. I set them at 34 cold, and that's WAY less total grip than I'm used to, but I just left them as they were and worried about my driving. Next time, I'll fiddle with tired pressures more.
Since Saturday night I've figured out a few things that I could've done differently. My starts need some serious work. Also, I'm now working on heel-toeing into 1st. I've got 2nd-5th dialed, but 1st is a whole different ballgame. Overall, I'm very pleased with how I drove. PCA posted the results of the official runs, and if I could've run officially and matched my best time, I would've finished 15th out of 22. Seeing how I had the slowest car out there (1970 1.7 with a tired engine and suspension, and no swaybars), I'm very happy with that.
Still, for next time, I think I need to push my lines a little harder. I didn't hit a single cone all night, even when I completely lost it. That tells me I'm not pushing hard enough. Not that I want to be out of control, but I need to be using up more of the track. Combine that with some better car setup, better starts, and my new heel-toe technique, my times should come down quite a bit next time.... as long as I can keep my head in it. That's where it all starts. Thanks again guys for all the help. You're awesome!
Mark D.
