QUOTE(BMXerror @ Jul 8 2007, 09:59 AM)
QUOTE(Dan (Almaden Valley) @ Jul 7 2007, 10:40 PM)
stock SCs and Carreras in the '70s and 80s ran 225s on 7 inch rear rims.
perfectly fine to run 225x50s on 7.5 rims.
You might want to run those up front and run 8s or 9s in the rear with 245s, since you will have flares.
225s on 7.5s will look kind of lost on the rear with flares.
I ran 225x50x15s (DOT Rs which are usually wider than street tires) on the rear of my 914-6 under stock (massaged) fenders
here it is with 225x50x16s on 7s on the rear for street use
I KNEW IT. I knew there were people putting 225s under narrow body cars, but I posted a thread about it (since I want to do it myself) and I got a whole in-rush of people saying, "No you can't do that... The biggest you can go is 205 and that's even a stuff-job." Did you have to do any sort of custom spacing to fit the 7s and 225 street tires under the rear? I assume you rolled the fenders a little. Sorry for the hijack, George.
Mark D.
yes the lips were completely rolled and the fenders themselves were pulled out quite a bit....it takes some time and some effort but they fit.
Fender work was done by a local body shop.
from the side it looked completely stock. from direcly in front of from the rear of the car you could see the definite extra bulge of the fender to allow the 225s and 7s to fit.
no spacers, 7x15 or 7x16 wheels with 225s for track or street.
