EdwardBlume
Jul 8 2007, 09:47 PM
I just pulled my motor last night and am trying to figure out what size bolt will fit through the engine case. I found a 17MM bolt / nut laying around but it didn't fit !!
type47
Jul 9 2007, 08:27 AM
do you mean that you want to mount an engine stand yoke to the trans end of the case? if so, the bottom threaded holes in the case where there are supposed to be studs for mounting the trans are 10mm threads, i think the studs are 10 x 92mm. the top holes are just that, holes which any bolt, long enough, will work....
re: the studs at the bottom of the case.... you can use a spacer (old deep well socket for example). if you don't have the studs, i think the thread pitch is 10 x1.0 so you could get a bolt at the hardware store.
EdwardBlume
Jul 9 2007, 09:49 AM
Thanks type 47!
I will go down to the HW store and buy a bolt.
toomanyinkc
Jul 9 2007, 11:12 AM
QUOTE(type47 @ Jul 9 2007, 09:27 AM)
I'm pretty sure they're 10 x 1.5
type47
Jul 9 2007, 11:17 AM
QUOTE(toomanyinkc @ Jul 9 2007, 09:12 AM)
listen to this guy about the pitch
