QUOTE(watsonrx13 @ Jul 10 2007, 01:18 PM)
QUOTE(dr914@autoatlanta.com @ Jul 10 2007, 03:53 PM)
yes there is a solution: Drop the dash it is easy enough to do from inside the front trunk compartment and then get the repro seal for 38.50 from an aftermarket supplier. The factory seal no longer has the steel in it and is a rip off.
George, you can drop the dash by unbolting it from inside the front trunk?
I have a car I'd like to replace the dash-to-windshield seal on, but I thought I'd have to remove the windshield to do it.... Can you give a quick step-by-step recount of what should be done?
-- Rob
yes Rob. The dash can easily be dropped to replace the seal. Drop the lower dash pad, drop the steering column (four bolts underneath) remove the side bolts and underneath screws that bolt the dash to the body, then go into the front trunk, remove the expansion tank, and blower nozzle tops, and unbolt the 10mm headed nuts that connect the dash to the cowl, then drop the dash, complete down slightly
