QUOTE(9146986 @ Jul 12 2007, 08:47 PM)
That's a lot of work. I mounted some right on the hard tube on the chassis. What I did on one install was use to swap sides (left flapper on right, etc), grind off the lever, re-index it, and weld it back on. Worked fine, and IIRC they were new ones like the photo.
You can probably get away with that method on a six chassis but not a four.
Click to view attachmentI already have to flip and re-index the arm on the driver's side for it to work with my single heat exchanger.
It looks like the angled tube is the way for me to go with the new replacement flapper on the passenger side and no need to re-index the arm.
Click to view attachmentQUOTE
... isn't the engine and tranny meant to move/vibrate in the engine and tranny mounts and hence, wouldn't that cause problems with a fixed solution like this?
The flexible tube goes from the flapper to the exhaust system instead of from the flapper to the body. It makes more sense this way because the actuating mechanism is no longer affected by engine movements.
