QUOTE(ConeDodger @ Jul 13 2007, 09:55 PM)
Just about anything you install in the rear trunk will prevent you from mounting the roof panel... Pull the motor. Do it right.
Pull the motor?!? Clearly I missed something, and am I must be out of context here, and am drunk3r than I thought, and will be begging for ConeDogger's forgivess later when I sober up since I clearly quoted him out of context.
I put my battery in the front/right corner of my rear trunk. In a plastic battery box. Fitting it and making sure it fit with the targa top in the trunk, with the lid down was NO trouble.
Just use your common sense and fabrication skills! A little carving and fabricating is exactly what we thrive on around here.
If you can't figure it out your own, then get some help. Plenty of that available!
