I've done a lot of research prior to posting and before I take her to the mechanic I want to make sure I haven't missed anything basic. Oh, 1974 1.8, stock car.
I drove for 100 miles and then the next morning, all of a sudden, the car runs like crap . The car starts no problem and holds an idle well. When I drive it feels like I'm on 3.5 cylinders. Especially in the higher RPM's and when I'm going uphill. The sound is off too. Letting off the gas will cause small backfires (lean characteristic, right?). All four plugs have no buildup and pure white insulators. Looks like a real lean condition.
Here's what I have done prior to this problem developing.
Replaced all vaccuum lines with the exception being the 4 manifold tubes (they look fine and solid). I can't find any leaks.
All new fuel lines.
New points, cap, rotor, condenser, spark plug wires, plugs. Dwell is 50.2 and timing at 7.5 BTDC at 800 RPM.
Fuel injectors rebuilt by Witchhunter Performance. Clean bill of health.
New fuses on relay board. Cleaned up connectors - no resistance.
Fuel pump runs and I can hear gas gurgling when I listen to the tank.
Also, I closed down the air bypass screw on the AFM and the idle increased a bit but higher RPM's and power still suffer.
Here's a wrinkle that may shed light on this. I have only two relays on my relay board. The two outermost relays; forward and aft. The fuel pump is grounded in the little area with four male connectors (rear passenger side). Should there be any more relays?
Relays aside, am I missing anything?
