jimkelly
Jul 16 2007, 06:05 PM
all old light bulbs since they can be bought at your local flaps and old bulbs seem to go bad for several reasons.
while i was replacing two bulbs - i had a third go intermmitant - it seems the base was coming loose from the glass.
i am gonna replace them all.
YMMV
jim
* what is the best thing for cleaning out corrosion on the socket contacts ??
SLITS
Jul 16 2007, 06:18 PM
QUOTE(jimkelly @ Jul 16 2007, 05:05 PM)
A round wire brush.
jimkelly
Jul 16 2007, 06:22 PM
wire brush -
- thanks - jim
QUOTE(SLITS @ Jul 16 2007, 04:18 PM)
A round wire brush.
SLITS
Jul 16 2007, 06:24 PM
Pelican used to sell an electrical cleaning kit with exactly that!
Rattle can chemicals will not remove all the corrosion.
type47
Jul 16 2007, 06:26 PM
you can get a round wire brush at the hardware store that is used to clean copper pipe before you solder it together. there is a tool that has a round shape and on the other end, it cleans the outside of a pipe.
geniusanthony
Jul 17 2007, 05:02 AM
use some dielectric grease also from flaps or hardware store in your bulb sockets. It will both prevent future corrosion and stop any intermitent(sp) failure, we hope
Kargeek
Jul 17 2007, 03:07 PM
Use a combination battery post and clamp brush. Electrical contact cleaner...
brer
Jul 17 2007, 03:16 PM
my electric bill is down 25% since I installed compact flourescents
Dr Evil
Jul 17 2007, 11:56 PM
Gun shop or Wal-Mart will have a barrel cleaning brush that should do the job as well. I upgraded to all LED and havent been happier.
Spoke
Jul 18 2007, 12:25 AM
I clean corrosion off of sockets with a small screwdriver or razorblade knife if it fits. just scrape the oxidation or rust off and spray with electrical contact cleaner to clean the terminals and wash out any debris.
orthobiz
Jul 18 2007, 05:31 AM
QUOTE(Dr Evil @ Jul 18 2007, 01:56 AM)
White LED's in the original holes? I have to admit, my dash lights are TIRED. Is there an LED bulb that fits in the original socket or is it like a string of Christmas lights? Pardon my ignorance...
Paul
BarberDave
Jul 18 2007, 05:56 AM
I got mine from " L E D TECH" i believe thru a poster here. Installing them
along with all rebuilt Gauges next week. I hope!!!!!
Dave
Dr Evil
Jul 18 2007, 09:51 AM
They are not hard to find at all. I got mine from www.superbrightleds.com
You want the BA7s bulbs. Their web site is a pain to navigate (not very intuitive) so here is the link. $.89 ea and have the preferred wide angle lens:
http://www.superbrightleds.com/cgi-bin/sto...cgi?product=755
type47
Jul 18 2007, 05:22 PM
QUOTE(jimkelly @ Jul 16 2007, 04:05 PM)
wait a minute, if you are changing bulbs that are still good, you are not a CSOB.
rfuerst911sc
Jul 18 2007, 06:12 PM
QUOTE(Dr Evil @ Jul 18 2007, 07:51 AM)
http://www.superbrightleds.com/cgi-bin/sto...cgi?product=755Hey Doc when useing the LED's don't you lose the ability to use the dimmer? If so have you found that to be a issue? I know the 911 guys generally find the LED's a poor replacement because of the straight beam vs. a wider beam from the conventional bulb, do you find that to be true with the 914 gauges? Just trying to get educated
Thanks
