QUOTE(turbo914v8 @ Jul 19 2007, 08:43 PM)
Holy crap Paul, I never realized you were at 1000HP. I am guessing turbo lag was the only way you could really drive it Most 1,000HP cars basically feel like the throttle is an on/off switch which makes them really tough to "drive". Maybe it was the chassis flex helping absorb the launches
...Turbo lag was non-existent...
...The door opened with a pop, the back went up at the same time the door hit the ground. I knew it was over....
I figured having twins you didn't have much if any lag - that was my attempt at being funny
hahaha. That monster 418 was much the same - just no real lag and also around 30psi with both of them. The turbo technology is so good now the ball-bearing turbos these days especially - that unless you just plain go too big, there will be little to no lag. And spooling a turbo to make 15psi each with a V8 isn't that difficult.
As for the door being a structural member, it is amazing how much support a door gives to those cars. When I hacked mine up, the door was the only thing keeping the two halves from separating! I showed up and they had the doors open and the back was slowing bending itself off
Take the old chassis, build a full tube chassis, then shell the two halves and fit it over the chassis sorta like I did. I really think that is about the only way to work with that much power
Well I have to say that I think you're 100%right. I totally love what you have done with your killer 914, but I don't have the skills or the time to learn how to build a chassis like yours. I have to fab it all my self. I have a lot of great ideas but don't have the bank to make it all come true. So for now, the plan is to tube a good strong chassis and keep the boost down. At 30 psi I generate 1000hp. There is no need to run 30psi all the time
Well no need to run 30psi at all. I can run an easy 12 to 16psi and have 600 to 700hp on tap. Still over kill, just enough to keep me and every one else scared.
Yeah, well I should note that one of the only things I didn't do myself was build the chassis. I designed it and spent every Saturday and one night during the week at the chassis shop going over the progress and fixing any mistakes the chassis shop was making along the way during the 8 month period to do it, but the bending and welding was not by me. My learning curve on getting nice, equal bends would have been long and tedious.
However, if you are going to bend your own cage, I would say bend your own tube chassis and tack everything in place and then hire a professional welder to do all the welding (we had the whole car damn near assembled with only tack welds!!! Once I was happy with every step of the fab, then I gave the go ahead to weld). Use the body as a guide and keep the suspension mount points to make your life easy, then just tube everything else and in the end chop the floor out and skin the bottom with aluminum. Getting suspension mounting correct is the PITA and without the right equipment (bumpsteer gauges, alignment tools, etc) you can mess a suspension up pretty bad, so keep those "sections" of hte 914 and reinforce/tie all points together so the rest of the car is dead weight. Then cut away the dead weight.
IMO by the time you weld enough tube into the stock chassis to handle even 600HP you really have a tube chassis and dead weight
Also my whole chassis was only ~$10K (which I know is a LOT of money as I too am far from rich) but if I did it myself there is maybe around $5K-7K of material cost for the chromoly. If you aren't as concerned about weight, DOM is even cheaper to the tune of about 1/2 the cost, and you could use less material. I put a ton of bar in the car to have all kinds of safety should I decide to take out a wall...
Oh yeah,
