QUOTE(nick mironov @ Jul 25 2007, 09:15 PM)
See the following 2 options for converting a 74-75 tachometer. (Earlier tachometers are different - see pdf attachment). Nothing special required with an HEI distributor. I converted two tachometers - one using the resistor method and the other using the capacitor method. Both methods worked. The problem was that both tachometers were crap to begin with - they had no damping and would grossly over-react causing the needle to swing back/forth until it settled down.
I finally gave up and got a tachometer from
bigmarkdesign. Very nice. $150.
Hope y'all can help! I have a tach dated 9/74… the one with the calibration pot. I want to convert it for v8 use. I am looking in the same area as in your photo. My tach already has 3 resistors mounted on the board! As far as I know this tach came out of a 4 cylinder car. What gives! It does have a 0.22 capacitor in place. Somewhere around this forum, I also saw someone who replaced the 0.22 uf cap with a 0.10 uf cap with the same results. Any thoughts?
Thanks!
