QUOTE(904svo @ Aug 20 2007, 04:51 PM)
QUOTE(Zaney @ Aug 20 2007, 03:30 PM)
Ok, I purchased a new relay and a new relay socket.
I used the electrical diagram in Hanes for a USA 74 for the fog light relay.
The socket has an extra wire not to be used. I tested the socket for continuity to correctly id the wires to pin sockets. Connected the socket wires to the appropriate wires in the fuse panel and... nothing.
When used the extra 87a wire instead of the 87 the lights would come on without the key in the ignition and the fog light switch off?
Where and how should I trace any issues backwards?
Any help is greatly appriciated
White/yellow to 87 on relay (normal open contact)
Red/black to 30 on relay (power from fuse #1)
White/blue to 85 on relay (relay winding power)
Gray/red to 86 on relay (relay winding to fog light switch this lead gets grounded
when Fog light switch is operated #30 on switch goes to ground (brown wire)
87a is normal close contact on relay.
Hope this helps you.
Ok, here is what I have found out,
According to the wiring schematic from PP for a '74 the wires should be as follows, at least what I can read:
For J5 Fog Light Relay
BLK/RED 30 to S10 fuse (HORN WORKS)
Grey/RED 85 to K terminal on fog light switch (switch works and lights up)
White/Blue 86 to S1 fuse (high beams and panel high beam light work)
White/Yellow 87 to fog lights (No POWER)
extra wire for 87a has power to it without the key in ignition
Before I pull the fog light switch, I have power at the 30 pin and 87a pin on the relay. When I pull the fog light switch, the number 10 fuse pops.
Possible related issue, everything else works with the lights except I do not have hazards or turn signals with the headlight switch activated. I am trying to divide and conquer but it is frustrating.
I have tried to research as many thread as I can find but am running out of patience.
Any ideas are welcome!
Thanks!
NAte
