GaroldShaffer
Jul 25 2007, 10:15 PM
Ok car is painted, new windshield installed, but the F'n trim wont stay down
New clips were installed, but the trim keeps coming up in the lower corners. I wish I would have went with my gut and used the black rubber seal, but NOOOOOooo I 2nd guess myself and went with the old chrome trim
So now I'm screwed, right? If I want to go to the rubber trim I have to pull the windshield to do it. $#@!@#$!%$%#^&%# Anyone know of a good windshield shop in Northwest Indiana?
McMark
Jul 25 2007, 10:28 PM
I bet the lower section won't stay down because the window was installed too low and the clips bump into the glass. If the clips can't open up enough to accept the trim, then it will never actually clip into place. There is a very close margin for installing the glass and some replacement windshields are better than others. Andy installed his rubber trim after the glass and used urethane to glue it in. So far so good.
SGB
Jul 25 2007, 10:36 PM
I just try not to look at mine, and never push it back down (thats just starts the "cycle of frustration").
IronHillRestorations
Jul 26 2007, 08:40 AM
One thing I do is make sure all the trim is nice and smooth, and fits the glass perfectly, before you install the glass. I always use new clips too, sometimes old clips don't grip the glass very well. Bummer Garold, messing with the windshield is always tricky.
dr914@autoatlanta.com
Jul 26 2007, 09:14 AM
We encountered this long ago. There could be two problems. First, some aftermarket windshields are miscast by design and those 'shields stick up too far in the corners. The solution here is to replace the windshield with an approved brand. Also if the installers did not us 1/4 inch butyl tape then the windshield will stick up too high and the windshield chrome will not stay down.
GaroldShaffer
Jul 26 2007, 10:03 AM
QUOTE(McMark @ Jul 25 2007, 08:28 PM)
I might try what Andy did, what do I got to loose. Still pisses me off.
boxstr
Jul 26 2007, 11:19 AM
Garold, Sorry to read about this after the fact. You can install the rubber trim after the windshield has been installed. The only negative is you may see some of the body under the glass around the perimeter.
If you look at the new cars that use the rubber trim they have a black band on the inside of the windshield. This hides alot of stuff that you don't want to see.
CCLINGLASSISUS
neo914-6
Jul 26 2007, 11:35 AM
take some measurements of the depth of the clips and compare to the depth of the trim frame lip. That should tell you if the glass and seal to body stack tolerance is too great. If it's the butyl, you can remove and reinstall the glass with the right thickness seal.
did the rear view mirror work out ok?
dinomium
Jul 26 2007, 05:50 PM
just DONT try to force the trim any more, or you will get to buy a whole new windscreen!
