QUOTE(McMark @ Jul 26 2007, 08:53 PM)
IIRC, the cup bolts get 50. It's in the Haynes, but you have to speak Haynes to understand which one is which. It's the control arm bearing on body, or some such.
Yeah I read it but apparently wrong. I thought they meant the nut on the body mount and the other the pivot bracket that Haynes calls the Control arm bearing:
Control arm bearing//body @ 50 ft/lbs.
Control arm bearing/control arm@ 108 ft/lbs.
Are both the nuts on the control arm 108 ft/lbs.?
BTW did you call Mueller, he thinks you're avoiding him, LOL?
