TonyAKAVW
Jul 26 2007, 08:40 PM
http://www.honda-tech.com/zerothread/1613435That is one amazing piece of mechanical engineering. I'm still trying to figure out how that thing even works. I'm also thinking that it might be interesting to see if a sequential shifter could be made using solenoids so that you could use paddles. Where's Mueller when we need him?
-Tony
Allan
Jul 26 2007, 09:14 PM
Don't have time to really research it so...
A bump for a friend....
Dr Evil
Jul 26 2007, 09:56 PM
Very cool! It looks as if the solenoid is for the side to side translation (pre programmed) and the fore and aft is given by the person. That would take some time to design.
Dr. Roger
Jul 26 2007, 10:14 PM
KaptKaos
Didn't the MR2 Spyder come with one of these?
sww914
Jul 26 2007, 10:53 PM
Beautifully machined piece. My brain just melted trying to understand it. FUUHHHHGHHUUFFUUHH. Bluh
URY914
Jul 27 2007, 08:04 AM
WOW!, he must have an awesome set of tools to build that thing.
I gotta give the kid credit, it is sweet.
IronHillRestorations
Jul 27 2007, 08:09 AM
A sequential shifter is really only for race cars and wouldn't be very good on a street car.
brer
Jul 27 2007, 10:19 AM
you can use a barrel with a machined groove to run the gear selector.
the barrael rotates forward or backward to change gears.
Mueller
Jul 27 2007, 12:51 PM
BahnBrenner914
Jul 27 2007, 01:32 PM
Yeah, paddle shifters sounds like a great idea, for a racecar. I think I might put my ME degree to use in a couple years if I decide to build a race-914 and get some paddles, but as for a road car, it'd be more of a pain.
bondo
Jul 27 2007, 01:37 PM
Wow, that's crazy. I can't believe he can do all that at the shifter, with no mods to the trans. (if I were to attempt something like this I'd put the mechanical bits at the trans and only use one cable)
andys
Jul 27 2007, 03:57 PM
Tony,
You can design a sequential shifter if you already have a cable shift set up by using a linear cam to translate gate and selector motions. It's not real complex (think motorcyle, though they use a drum). If you have a shifter rod, then it becomes much more difficult.
There's also this one.
http://www.takakaira.co.jp/performance/ike...eya_manual.htmlAndys
zymurgist
Jul 27 2007, 04:09 PM
Wow, that's a work of art!
Jul 28 2007, 11:42 AM
But unless you are only racing, it's a total pain for a street car. OK, coming to a stop, make sure you go through each gear to get down to first.
Cool hardware though, but no good on a driver.
My friend Martin Arnaud said he tried driving a (barely streetable) track car with sequential shift on the street and it was a total PITA!
scotty b
Jul 28 2007, 06:13 PM
QUOTE(TonyAKAVW @ Jul 26 2007, 06:40 PM)
-Tony
What the hell were you doing on a HONDA site............. ?
TonyAKAVW
Jul 28 2007, 11:54 PM
I was searching for Porsche shifters because I want to rebuild my shifter. I'm planning on a complete ground up design similar to the modern Porsche cable shifters. Then this thing came up and I was stunned. Amazing piece of work. I think I'm still going to stck with a normal H-pattern though.
-Tony
jd74914
Jul 29 2007, 03:12 PM
I wish the honda link would work, we must have killed it.
Forgive my ignorance, but with a sequential shifter (of the manual variety IE: without solenoid) the shift lever doesn't return to center does it? If it doesn't than one of these would not be too difficult with make utilizing a cam as stated above.
