QUOTE(marks914 @ Jul 30 2007, 09:30 AM)
Thats the route I was going to go before I found a 1178 crank. Should be no problem to put together, you will need 350 pistons with a pin heignt of 1.5 in i think because the rod length is 5.94 inches I think with 58 CC heads the CR is around 9.5:1
I could not be happier with my SBC 302, it was the right thing to do for the car.
You wil probably have to go hydraulic on the cam, which will limit you to 6500 RPMs or so.
mark
I *think* and correct me if I'm wrong, all of the 87-92 engines are roller cams? But still, I would just go hydraulic roller. I'm not looking for a screamer, just a good match for the 901. 6500 sounds perfect.
What about pistons, cast or hypereutectics?
