QUOTE(jim_hoyland @ Jul 31 2007, 08:50 PM)
My summer engine temps have been running in the 210-220 range this summer, particularly in traffic conditions.
Removed the rain tray, the engine temps appear to have dropped 20 degrees. I'm running 180-200 now.
Was curious if others have found the same
Jim
QUOTE(SGB @ Aug 1 2007, 07:40 AM)
Does anyone know what volume of air the engine fan pushes? I guess it would be a relationship of RPM to CFM, and probably isn't linear. And then there is the volume of air inducted for combustion, too. I'm theorizing about car speed and ram-air, etc. just wondering what quantity of air would need to be pushed into the engine bay to surpass the low pressure induced by all that air flow out of there. Perhaps it is reasonable to try to increase air going in, but there is too much rain around here to remove the tray, so I'm wondering if it would be worht it to try to increase access of outside air to the engine bay some other way...
IF those are oil temps., according to Jake's radio show they are normal. Below 180 is getting too low and 220 is getting a bit on the high side but still ok. Oil temps. and CHT are two seperate things and for the most part DO NOT correlate.
I would also interested to know how much air flow the engine bay would need to create a positive or equal pressure.
