Engman
Dec 17 2003, 05:55 PM
Engman
Apr 13 2004, 01:10 PM
I also have the trunk reinforcements for the rear sway bar mounts.
Engman Parts has all the details.
M
Apr 13 2004, 02:31 PM
cool! do you also have brackets for mounting the sway bar inside the trunk, like they did on the GT's?
Andy
Engman
Apr 13 2004, 02:32 PM
I am ignorant on that one. Is there a pic somewhere?
M
Apr 13 2004, 05:06 PM
QUOTE(Engman @ Apr 13 2004, 01:32 PM)
here you go ...
914werke
May 17 2004, 09:18 AM
How about a pic of the trunk reinforcements and another of thier installed location?
Engman
May 17 2004, 03:40 PM
Here is a pic of the reinforcements....
Engman
May 17 2004, 03:41 PM
And the location is easy - right againt the rib at the top on each side... Shown is the drivers side shot from the rear...
Engman
May 19 2004, 01:35 PM
Andy - here is borrowed pic of what I think you are referring to.
M
Engman
Sep 20 2004, 04:44 PM
75-76 rear sway bar mounts - as shown below, Please see
M
monkei
Sep 28 2004, 10:18 PM
can the top still fit in the rear trunk with the sway bar installed as shown above?
Engman
Sep 28 2004, 10:28 PM
The in trunk mount has not been made and is not currently available. This was a discussion Andy had on the subject a while back. If it WAS available it would not interfere with the top - too much distance between the two.
M
monkei
Sep 28 2004, 11:05 PM
thought that looked odd, how does it mount then: from trailing arms or a arms to the reinforced trunk mount? you have any pictures of a rear sway bar setup installed with the brackets? this would be used with stock rear bars?
